Pinnacle Studio DVplus for £140?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by JIT, Feb 20, 2003.
  1. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    I am completely new to DV editing and am looking to buy an editing card, i have been reccommended the Pinnacle Studio DVplus but would like some opinions as to whether it is any good. Also any sites where i can buy it, thanks.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    I found Pinnacle Studio DV on www.dabs.co.uk for £81.07 inc VAT
    and Pinnacle Studio DV Deluxe for £199.75inc
    The deluxe edition allows you to capture analogue & digital formats. The standard version is only digital.Pinnacle Studio DVplus is digital only capture, but analogue output for creating VHS etc tapes and costs £135.12inc.
    Pinnacle Studio 8 is a highly recommended editing package for beginners (and even more advanced users!) and has a lot of good features. Take a look, and if it does what you require then I would say it is as good as any in the price range.
    Check the specs of your PC and also make sure that you have plenty of spare disk space. DV footage will take 4Gb of space for every 4minutes captured :eek:
    Good luck
    Mark.
  3. raneeshm
    raneeshm
    Jan 23, 2003
    24
    carmarthen
    try amazon .co.uk, i found pinnacle the cheapest there
