Pinnacle Studio 8 rendering problem
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by mab25, Jan 14, 2004.
  1. mab25
    mab25
    I'm having problems rendering a DVD movie in Pinnacle Studio 8. The video is about 1hr 10 mins long and I have set the bitrate to 6500 which gives me a few of spare minutes on a DVD-R.
    I have chosen the option to create an image to disk instead of burning the DVD as I will be doing the burning later.
    The video is made up of a very large number of clips and also has titles and music.
    About 30 seconds after it starts rendering it fails with an error,something like "Failed to create disk"
    Is there a limit to how many clips Pinnacle Studio 8 can handle. I've created and burnt many movies before although containing less clips and to SVCD (about 25 mins long) and not DVD. This is my first attempt at creating a DVD.
    Any ideas why my movie fails to render almost immediately.
    Thanks,
    M.
  2. Brian110507
    Brian110507
  3. mab25
    mab25
    I cut down my video to 55 minutes by removing some of the clips and it rendered fine.
    I can only assume that this is another bug in pinnacle studio 8 where it can't render when there are a very large number of clips or a very long movie.
    M.
  4. matty2767
    matty2767
    try making an avi first. then convert it to a mpeg in tmpgenc.
