Pinnacle Studio 8.3.17 Make Movie DVCODEC.DLL error
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by brado, May 17, 2004.
  1. brado
    brado
    Jan 16, 2004
    130
    16
    Worcester UK
    Having read other peoples problems with Studio 8, I have been able to set up my computer, just for editing. This has cured most of the troubles, but I have one major problem left. That is when I have finished an edit and go to output to tape, Studio has to close because of an error in DVCODEC.DLL.
    When I first used the program, I had no problems at all. I made several AVI. files, output 2 projects to tape and made 2 VCD's. then when I came to edit another project, problems started. Since then I have removed the software completely and reinstalled, twice.
    Before using Studio, I remove all unwanted start-up programs, stop screen saver, stop energy saver and keep over 200Mb of RAM free.
    There are several posts with similar problems on the Pinnacle forum.
    Any advice would be most welcome.
  2. brado
    brado
    Jan 16, 2004
    130
    16
    Worcester UK
    I have now put my problem to Pinnacle and their automated reply was to update the software to 8.12.7 which I have done.
    I now get errors on diskio.dll and on closing an error on mfc42.dll.
    Has anyone had the same problem?
  3. melliott1963
    melliott1963
    Nov 27, 2001
    427
    Ilford, Essex
    +4
    I've been using Studio for a few years now (since version 1 - I'm now on version 9) and whilst I've experienced a few bugs along the way, I've not come across these problems so can only assume there is something with your PC's configuration that's conflicting with Studio.
    I've done a quick search on Google and there are a few articles with people having a problem with diskio.dll when using Studio. You might also like to look at this article about mfc42.dll: http://www.techadvice.com/w98/M/mfc42_dll.htm
    Hope this is of some help.
  4. brado
    brado
    Jan 16, 2004
    130
    16
    Worcester UK
    Thanks very much for that help.
    SFC is designed for Win 98 and I am using ME. I hope it will work on ME.
    I will try it anyway.
    I will do a search on Google for problems with the other dll's.
  5. brado
    brado
    Jan 16, 2004
    130
    16
    Worcester UK
    Further to my last post, I now do not have a problem with any of those mentioned.
    I updated the bios on my ASUS board and my Nvidea graphics card, so now I can get as far as creating a video to tape. I will go no further because it cannot find the DV equipment, which is my camera, connected and switched on to standby. This has worked before the ealier problems arose.
    Next I tried making an AVI file first, which was OK. I then tried to make a tape from that, but with the same end result.
    Has anyone any ideas what could be causing this?
  6. scottydog7
    scottydog7
  7. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
