pinnacle plus v9.3 -capturing question
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by 90210, Jun 16, 2005.
  1. 90210
    90210
    Hi, I installed the above last night and did only play around for a couple of hours. Does anyone know if video files can be imported into this. I captured from camcorder ok but have some files on my pc i would like to edit but there wasnt anything obvious to import them with. I was using mm2 before and this had the option of importing files so thought this may be the same.
  2. melliott1963
    melliott1963
    Nov 27, 2001
    427
    Ilford, Essex
    +4
    I used to have Pinnacle Studio 9, so assume this version will be similar.
    When you are in edit mode, at the top left of the screen is a 'book' which shows all the separate scenes that have been captured.
    There's a drop down list that you can select the files from the current directory. Next to that is a small folder icon. Clicking on this will allow you to select another folder on your computer. Just use this to navigate to where your other files are.
    Hope this helps.
