pinnacle firewire
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by pug, Mar 5, 2002.
  1. pug
    pug
    hi there,
    i am having problems installing my texas instruments firewire card from pinnacle on winME. do i need the winME cd to install the correct drivers? i have installed the card by allowing hardware wizard to search for a driver but when i restart my computer it comes up with various exclamation boxes (ndetect has caused a problem) , the e-mail protection for virus' is disabled and i can't connect to the net.
    please help, i dont know what to do
    cheers
  2. Gurubarry
    Gurubarry
    Hi Pug, I use a Pinnacle card with ME. To re-install it you have to very carefully follow the instructions, 'cause there is a bit about the order of installation in there. If you can swap the card into another slot, this sometimes works.
    hope this helps ,
    barry
  3. Skid Solo
    Skid Solo
    Nov 13, 2001
    98
    Hertfordshire
    I found the only way I could install this card, was to actually connect a video camera and have the video camera turned on during installation. No more problems after this.
  4. Timmie Boy
    Timmie Boy
    Jul 16, 2000
    54
    Pug
    What do Pinnacle say about installing the card? You've obviously followed their instructions?
    I have installed the same card that came with Videowave 4 and it instructed that I use the driver that came with windows 98 cd. So maybe with Win Me you have to do the same.
