Pinnacle DV Version 8.3
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Keylock, May 13, 2003.
  1. Keylock
    Keylock
    Recently purchased above package for my PC. Installed PCI card and firewire and package. It worked fine caputuring some footage and editing initially. I then went to work on the same footage the next day and one the title editor wouldnt work ie it wouldnt let me put in a title. 2 It wouldnt let me add music. 3 When I went to burn a VCD it just froze at the rendering process. I also got a pop error. kernel32.dll. I uninstalled and reinstalled and again it worked for awhile, What is wrong? Help please! I have a gateway pentium 4, 1.5Ghz 80GB hard drive and a panasonic NV - Gs1eg camcorder purchased 2nd hand from a mate.
  2. scott69
    scott69
    Try the following...
    disable anti-virus software.
    Shut down all other programs.
    Defrag. your hard drive.
    Now try rendering etc.
    Pinnacle ( and others probably ) are very hit and miss. I have had no problems with studio 8, but there are lots who do.
    Try the website for the latest patch ( 8.5 I think ).
    Hope this helps.
    P.S. if problems remain try reinstalling it.
