Pinnacle 8 - DV or MPEG capture?
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by mab25, Mar 17, 2003.
  1. mab25
    mab25
    In Pinnacle studio 8, if I want to capture video that is going to be burnt as a VCD, is there any need to capture in DV format or should I capture in MPEG format.
    i.e. Would it make any difference to the final video, which of the 2 options I choose at the capture stage if the the final output is VCD.
    Also, what is VCD output comparable to. Would it be as good as VHS or SVHS ?
    Advice would be appreciated.
    Thanks,
    M.
  2. OGIII
    OGIII
    I think you'll find VCD to be not as good as VHS, I played around with this a bit at weekend and the biggest prolem is digital blocking on VCD, obviously when you transfer to VHS via a VCR you may get lower quality but it'll be smooth.
    I found that capturing as MPEG then making SVCD produced excellent quality albeit a bit time slow.
    OG
