rank_amateur
Can anyone help with my TV card problem? I've had no luck over at the actual MediaPortal forums so here's hoping you guys can help.
I have a Winfast DVT1000S card working perfectly in MediaPortal but I've been trying to add Freesat (Astra2/Eurobird1) channels using a Pinnacle 7010iX card too.
Firstly TV Server only recognises it as a 3010iX card (I think they have the same driver) which I wouldn't mind if it then worked -but it doesn't. I have scanned for channels numerous times on both the DVB S and DVB T inputs and only ever get the 'No Signal' message.
I have un-installed and re-installed the card a couple of times. I have completely removed it from the pc then put it back. I have also removed the Winfast card just in case there was a conflict. I have downloaded the latest Pinnacle drivers and also tried using the Black Gold BTG3540 driver after coming accross it, in another thread, as a possible answer. Nothing seems to work.
Device Manager recognises the card properly and says it is working properly. It also lists the correct BDA driver versions.
Any ideas? I'd really appreciate some advice as I'm no expert on computers so this has now left me completely stumped.
For what it's worth, MediaPortal runs perfectly other than this and I think it's a brilliant piece of software.
A few sysetms details:
MediaPortal Version: 1.0.2.0
MediaPortal Skin: StreamedMP
Windows Version: Windows 7 32Bit
CPU Type: Intel Core 2 CPU 4400 @2GHz
HDD: Samsung HD154UI ATA Device
Memory: 2GB
Video Card: NVIDIA Geoforce 8600GT
Video Card Driver: 8.16.11.9062
Sound Card: Realtek
Sound Card AC3: Optical
Sound Card Driver: 6.1.7600.16385
1. TV Card: Winfast DVT1000 S
1. TV Card Type: Analog
1. TV Card Driver: 1.3.4.5010
2. TV Card: Pinnacle 7010iX
2. TV Card Type: Dual Analogue+DVB-T+DVB-S
2. TV Card Driver: 6.0.3.9
Remote: MCE
TV: Sony TV, Optoma projector
TV - HTPC Connection: DVI-HDMI
Many thanks.
Memory: 2GB
Sound Card: Realtek
Remote: MCE
Many thanks.
