Pinnacle 7 to VCD/SVCD
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by PanMan, May 2, 2002.
  1. PanMan
    PanMan
    Jan 17, 2002
    50
    Having edited my movie, and outputted it to SVCD format via the Make Movie option on Pinnicle 7, I am left with a large MPG on my HD. I have copied this over to a CDR via Adaptec EasyCD 3.5c and put it in my Wharfedale M5, but although the display on the front of the M5 says it is trying to play a VCD, it will not go beyond the Wharfedale welcome screen, and play my movie. Can anyone help? Am I not copying the correct files? My players manual does state that the machine will play both VCD and SVCD discs.
  2. steev
    steev
    Oct 22, 2001
    238
    19
    Beds, UK
    VCD and SVCD need a special directory structure and various files present. Go to good old http://www.vcdhelp.com for information on burning these formats.
    I used TMPGEnc to make my SVCD MPEG file and VCDEasy to burn it. The quality was much better than the Pinnacle codec.
    My Acoustic Solutions DVD will play a CD with just the MPG file, but you lose the ability to fast forward.
    HTH
    Steve
  3. JefUK
    JefUK
    Mar 31, 2002
    448
    28
    +54
    Roxio EasyCD will not write SVCD only VCD. You need the Deluxe Version, which contains VCD Creator, to set up the special file structure. The file must also be a compatible MPEG1 for VCD. EasyCD will chech the file.
    For SVCD use Nero, and the files must be MPEG2.
    Steev is right, especially for VCD use TMPGEnc to encode to MPEG1 for maximum quality. It is better than the S7 encoder, but much slower to get the better quality.
  4. PanMan
    PanMan
    Jan 17, 2002
    50
    Cheers Steev and JefUK
    http://www.vcdhelp.com/ is an excellent website, and probably essential for anyone making thier own movies. I now have both VCDEasy and TMPGEnc, and have just watched my first home-made SVCD of my hols on my DVD player - thanks!
