Pink noise wanted!
Discussion in 'AV Receivers & Amplifiers' started by sacd, Dec 21, 2004.
  1. sacd
    sacd
    Feb 19, 2004
    297
    Cardiff
    Hi! Like the true geek that I am I have just got hold of a sound pressure meter to callibrate my yamaha ax1.
    Only problem is that I have no test signals to help with this.
    I need a set of pink noise mp3's from around 100hz to 16000khz.
    Anybody care to e-mail me some?
    Ta!
  2. Mandel
    Mandel
    I have a feeling that mp3 encoding would trash a pink noise signal :-O
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    If you can connect your PC to your hifi then you could download a signal generator like NCH which has a pink noise generator.
  4. sacd
    sacd
    Feb 19, 2004
    297
    Cardiff
    Thanks for that, I have nowo got a copy of NCH. But what sort of wave form pattern is the best one to use?
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Well, the nature of noise is that it should include the whole frequency spectrum so you'll only be able to test overall output with a noise generator.
    For test tones, the only thing you should send to your amplifier are sine waves (the curvy ones). The others have the potential to do quite a lot of damage to your equipment. :)
  6. sacd
    sacd
    Feb 19, 2004
    297
    Cardiff
    Thanks, I thought it might be sine waves because everything else was far too sharp on my ears!
    My amp has a variable test tone generator which tests each speaker in increments up to 250hz for bass response testing purposes.
    However, I now realise that the nch generator is only 2 channel. So I will have to find some sort of source that will give me sine wave frequency increments that pans around the different channels.
    I wish i had never started this!!
  7. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    That would have to be a digital source. Something like Avia Pro (or even vanilla Avia or DVE) might do it, I've no experience of them I'm afraid.
  8. mikeycrawford
    mikeycrawford
    Nov 27, 2002
    116
