Pinhole Camera with Camcorder
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by porto99, Sep 11, 2005.
  1. porto99
    porto99
    Is it possible to get a Pinhole camera and attach it to your helmet and then connect it to a Sony Camcorder DCR-HC22E in your back pack?
    This is for a hiking holiday and recording mountain bike routes.
    The manual says that the HC22E DV has input/output via the iLink jack, so are they any of these small cameras what work with this interface?
    Also if they are what about power, is that from the camcorder.
    Any feedback, that would be great.
  2. lurcher
    lurcher
    May 15, 2003
    4,114
    Stalybridge
    +202
    You will need to go up a model to HC32 to get a/v in to allow camcorder to record analogue signal from bullet type cam. Wont work on iLink terminal.
  3. porto99
    porto99
    Just one follow-up question.
    Can this iLink be used to copy a miniDV tape from one camcorder to another.
    Also are they any accessories that could extend the funtions of the camcorder. Yes I think I should have gone for the better model.
    Many thanks,
    Porto.
  4. melliott1963
    melliott1963
    Nov 27, 2001
    427
    Ilford, Essex
    +4
    As far as I'm aware, the iLink connection will only allow you to connect your camcorder to a computer, not another camcorder.
    However, all you need to do is capture from camcorder to PC, change the tape in your camcorder, and then save from your PC back to the camcorder - I do it all the time, although the saving back to the camcorder usually happens after I've done my editing, so that if ever I need to get it back, I don't have to go through the editing process again.
  5. Roy Mallard
    Roy Mallard
    You can dub from one camcorder to another using a 4pin-4pin firewire cable.
  6. Roy Mallard
    Roy Mallard
    provided the record cam has dv in,obviously, which the hc22 has.
