Not very old then. Try the service menu as 'Pug72' has suggested. Do make a note of all the settings first so you can go back to them if need be). On the subject of aspect ratio - do make sure that the aspect ratio of what you're watching is how the broadcaster intends it to be watched in - on your particular tv - before you make any adjustments. It's easy to get confused. Regards, yt.
