Pin connections for VGA>5xBNC cable?
Discussion in 'Projectors, Screens & Video Processors' started by Messiah, Sep 3, 2003.
  1. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Anyone have the correct pin connections for a BNC to VGA cable. I bought all the bits from VDC a while back but did not end up getting another CRT so feel I make as well make up the cable anyway and then sell on.
    Thanks.
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Pin connect as follows
    1. Red
    2. Green
    3. Blue
    4. Monitor ident (leave blank)
    5. Ground
    6. Red Ground
    7. Green Ground
    8. Blue Ground
    9. No pin
    10. Sync Ground (H&V) twist them together some how
    11. more idents leave blank
    12. even more idents leave blank too
    13. Horizontal sync (or combined sync if using 4 wire) (tradition uses black)
    14. Vertical sync (usually white, grey or yellow)
    15. yet another ident to leave blank
      [/list=1]
      Hope that helps
  3. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Thanks Roland, that will do nicely :) Much appreciated.
