B
big_ears
Hi, I wd like to upgrade my system as I found it too bright and lacking in the bass dept. I have tested the I30 in a home trial and found it most suitable for my set up giving a very warm, textured and excellent image sound. I tested Rotel 03 and Cyrus 6vs/8vs with the 11Ls and they didn't perform as well. But, is the I30 an overkill? It's really too expensive.
I play mostly jazz, vocals, pop and classical guitars in a medium sized room.
Thanks in advance for your advice.
NAD 320BEE, NAD 542CDP, QUAD 11L, STRAIGHTWIRE SYMPHONY, CHORD CARNIVAL
