pictures has moved to the left
Discussion in 'Blu-ray & DVD Players & Recorders' started by sharper, Jan 19, 2004.
  1. sharper
    sharper
    Jul 24, 2002
    588
    SW London
    +11
    I know I've seen something about this many times, just cant remember the answer.
    DVD (goodmans 134) fitted to portable (sony) and the screen has moved left cutting the edge off.
    ta
  2. mjcairney
    mjcairney
    Oct 26, 2003
    6,854
    2
    4
    137
    Airdrie, Scotland
    +834
    I don't know if this will work - on my 36" Sony TV, when an RGB signal is being received, it is possible to go into the set-up and move the picture right or left but, as I say, I don't know if you will have this option on a portable set or not.
    Hope this helps.
  3. Zoidy
    Zoidy
    i have this problem. never been able to cure it.. only happens with R1 discs, just grown to ignore it :) i can only assume its the dvd player..
