picture & sound seetings for philips 30PF9946
Discussion in 'LCD & LED LCD TVs' started by sparky76, Mar 17, 2005.
  1. sparky76
    sparky76
    Mar 17, 2005
    11
    hi all, what are the best settings for this set, i have it connected to sky+ on scart 1 (using scart lead that come with sky) and a jvc dvd player, i have found settings for other philips models but not this, any help appreciated
  2. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Hi Sparky!
    This is one of the earlier generation Philips TV's and very little has been written about it here. Have you tried a search? This may produce some results from last year, before the likes of the 9986 and 9976 Hijacked the Forum!
    Basically, you'll need better Scarts for your connections. The 9946 only has one RGB Scart and one composite. If you want the best from the TV then an RGB enabled Scart switcher would be advisable. (Get on in Comet.) As for Scarts, get two £5.99 ones from www.tvcables.co.uk
    This will allow you to hook up your Sky and your DVD player with RGB scarts for the best possible piccie.
    If you have a VHS recorder, use the crummy scart for that and plug it into Ext2 on the TV which is non RGB.
    Jimmy
  3. sparky76
    sparky76
    Mar 17, 2005
    11
    yeah i was thinking about changing my scarts, will do that and get a rgb switch, any ideas on the settings (mainly picture, got amp for sound), i have seen them put here for the newer models but not this
  4. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    Not familiar with the 9946, but, as a general rule, set the sharpness well down the scale - virtually as soft as possible. It's really up to you. With a good source signal you'll find it easier to get the picture as you like it.
    Jimmy
  5. sparky76
    sparky76
    Mar 17, 2005
    11
    just ordered vivanco sbx-94se switch box and a couple of QED P2110 scarts, should help with the picture, thanks for the help :thumbsup:
  6. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    ATTABOY!
    Jimmy
