Picture size/positioning via VGA in RGBHV
StooMonster
New challenge of the day...
How to get perfect picture positioning via VGA socket?
Perfect positioning a PC native resolution is easy, via the "snap in" method (as discussed in lots of threads).
What's the best way to position a 576p(625p) RGBHV signal via VGA socket?
I ask because every television channel on SkyDigital (and some DVDs) appears to be a different width, height isn't so much of a problem.
Is there a tried and tested methodology to achieve this?
I have thought about centreing channel selector box, by using tape measure or ruler :clown:, and the adjusting horizontal size until no black borders or fades on each side. But this seems a bit heath robinson compared to the PC "snap in" method.
StooMonster
