Picture settings
Discussion in 'General TV Discussions Forum' started by BallJoint, Aug 6, 2002.
  1. BallJoint
    BallJoint
    Sorry if this is a rather daft question, but with all the comments floating around the place about contrast and brightness I was wondering if there were any ball-park settings to give the best picture. Is one more important than the other? I realise that it is very much a personal thing though.
    The brightness is set at 52%, contrast at 65% and colour at 47% on a PW6006.
    BJ
  2. juboy
    juboy
    I don't think you'll be too far out with those settings although it would be worth buying/borrowing Video Essentials or Avia if you can, that way you can calbirate the picture more accurately.
    Of the settings you list, it's possible the colour level may be lower than reference levels.
  3. BallJoint
    BallJoint
    Thanks for the info juboy. Will give it a go.
    BJ
  4. bobble
    bobble
    Jul 8, 2002
    159
    2
    +6
    Balljoint, if you have the T2 DVD it has a picutre set up section, goto sensory control and select THX on the terminators head. Its not very comprehensive, but may give you some guidelines.
    At the end of the day we probably all prefer things slightly different, if you are happy with your settings then things are fine!
