Picture Settings
Discussion in 'Plasma TVs Forum' started by eddyad, Nov 5, 2004.
  1. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    Do any plasma (or LCD) TVs have independent picture settings (Contrast, Brightness etc) for different inputs - RGB, composite etc.?
    There is a significant difference between input sources on my current CRT and while I rarely use Composite, it's annoying to want/have to change the settings that are good for RGB and then put them back.
    Source devices don't usually give possibility of adjustment.
    None of the reviews I've read mentions this.
    Thanks for any info
  2. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    Can't remember having used a plasma that only had one global set of contrast/brightness/colour/sharpness type adjustments. Panasonic, Pioneer, Fujitsu, Hitachi and NEC are all per-input colour settings.
  3. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    Thanks for reply. Now all I have to do is overcome problem with spending the sort of money involved. :rolleyes:
