Picture quality
Discussion in 'Xbox Forums' started by dodger747, Sep 19, 2005.
  1. dodger747
    dodger747
    May 5, 2005
    2,955
    Liverpool
    +209
  2. shaithis
    shaithis
    Feb 25, 2005
    1,635
    The Last Aerie
    +30
    Buy the VGA cable for the 360 and plug it directly into the monitor for the best picture quality :smashin:
  3. neil c
    neil c
    Mar 25, 2005
    537
    +3
    You'll want to forget about that VGA box straight away. That will give you THE worst picture you could attain from your Xbox 360.
    The Xbox 360 will have a VGA adaptor available from launch. That means it will connect directly to your monitor. If your monitor has decent circuitry it will scale the picture from the X360 so that you will see a 1280 x 720 resolution picture but with black bars at the top and bottom.
  4. dodger747
    dodger747
    May 5, 2005
    2,955
    Liverpool
    +209
    Thanks for the quick replies.
    I thought the box would give me a sh*t picture. Looks like the vga cable for me then :thumbsup:
    Thanks again.
