Picture Quality???
Discussion in 'Plasma TVs' started by edggie, Sep 8, 2005.
  1. edggie
    edggie
    Sep 5, 2005
    27
    Just been to currys looking at high def televisions. They had 4 different size LG Plasmas showing HD and they looked stunning. The 42" one had a 10000:1 contrast ratio and Resolution: 1024 x 768.
    I was looking at buying the Samsung PS-42S5HX which has the same contrast and resolution stats does this mean that the samsung will have as good a picture????? Help :confused:
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Ask Currys for a demo and see for yourself. Never trust other people's opinions when you're spending that sort of cash :)
  3. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    no it doesn't matie......there is so much more to it than that I'm afraid.....in fact everything has more to do with it than that.....the electronics, the components, etc, etc, etc. Search the forums for the screens you are interested in for research...and try and see them all, well set up at specialist dealers if you can and you will see the differences.
  4. edggie
    edggie
    Sep 5, 2005
    27
    Cheers. i find the more i know the more there is to learn!!!!!! :eek:
    Can anyone recomend a good 42"HD plasma for dvds and ps3 for £1500 :lease:
  5. johnhy
    johnhy
    Dec 8, 2003
    1,766
    Glasgow
    +101
    I think you should look at the Samsung you're talking about. In Curry's £1999 but you can get it online for aound £1500 and if you put a bit of work in get a JL pricematch too.For the money I think it's a good option I don't see the point in paying a lot more than that when you think how quick things develp etc.
  6. Lionheart
    Lionheart
    Samsung are always cheaper than Panasonic and give a comparable PQ...do you think they are being kinder to us :)
  7. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,735
    Norwich
    +625
    I would avoid the Samsung PS-42S5HX, I went to a mates to have a go at setting his up for him, he has been using a PW5 for about 3 odd years, and he couldn't get it looking anywhere near as good.
    We had a go at it, but it just isn't very good. The colours are false looking and as soon as there are any shadows it looks like you have turned it to 256 colours! He is renting and he is trying to get it swapped over.
    Avoid!
  8. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Programmed a pronto for a Samsung owner last night, not impressed either. But he got given his, so not too much to complain about. I was offered a batch for a reasonable price but turned it down. From my experience, and that of numerous others, PQ is not the biggest issue. Lots of people would be quite happy with the screen, you're not all as picky as Gizlaroc. It's the plentiful supply of sinks and soap at Samsung UK that's the problem. They wash their hands more often than NHS nurses.
  9. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,735
    Norwich
    +625
    Honestly mate, a friend asked me to look at the screen, he had 2 replaced already because he thought they were faulty. I said he was being too fussy, it is only in the spare room so why be so picky, but the image was awful.
    The funny thing is the DNIE function, if you view the demo it splits the screen in half showing the image with and without it running, the half without it running looks really good, the blacks are only grey but the image looks far better. But we could not find any way of turning it off for real, it is almost like Samsung are saying, this is the image you could have, but we won't let you! :mad:
  10. Not A Clue
    Not A Clue
    Not very often then :rotfl:
