Picture Quality scart V Component
Discussion in 'Home Cinema Buying & Building' started by Optiplex, Dec 5, 2004.
  1. Optiplex
    Optiplex
    Nov 29, 2004
    55
    I have just set-up my Panasonic SC-HT520 and it is connected to a Samsung 42" rear pro with component inputs and progresive scan capability. I am using Ixos leads which have been recomended.
    I noticed straight away the picture quality was not great. The colours were not very bright at all, even when adjusting the colour to nearly full up I was still unable to get what looked like a resonable red. Reds tend to look orange.
    I have therefore changed the connection to scart and right away have noticed a huge improvment.
    Can anyone point me in the right direction as to what I should look for when trying to fix this. I've been through the set-ups and menus over a dozen times and have run out of ideas. And yes I have checked all the connections.
    And finally, if anyone else has the 520 am I right in thinking it only has progresive scan for ntsc not pal?
  2. ste_d73
    ste_d73
    Dec 13, 2004
    26
    I believe you are right in your assertion that the pana 520 only offers prog scan on NTSC. So if your playing region 2 PAL discs this may explain the lack of picture quality.
