Picture Quality & Connections
Discussion in 'Blu-ray & DVD Players & Recorders' started by Steveford77, Feb 26, 2005.
  1. Steveford77
    Steveford77
    Feb 26, 2005
    17
    Tonbridge
    just bought a Panasonic E65. Connect my Sky+ box via the Panny to the Philips 6006TV using a brand new £40 RGB cable. However when I view Sky the picture is clear but much darker than previously and with a green shading. Am I doing anything wrong? DVD Recorder set to receive RGB on AV2.
    Might it be Scart cable? I spose I could try another one
    Steve
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    That does sound like a fault with the Scart Cable. Try using a different one (a cheapie if necessary) to see if you still have the same problem.
  3. Steveford77
    Steveford77
    Feb 26, 2005
    17
    Tonbridge
    I've just swapped the cables and get the same picture. If I use the cables and connect my sky box straight to TV then the picture is fine. So it seems as if the DVD recorder is changing the image - even when switched off and signal just passing through.
    Any ideas?
    Also my Panasonic Dvd says 'unsupported' when I insert a Sony dvd r- blank disk in. Whys that?!
    Steve
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    If it's not the cable itself then it could well be a faultly connection on the DVD recorder, i.e. one of the scart pins is damaged. Probably best to seek a replacement.
    Your not trying a DVD+R are you? The unit only records/reads DVD-R.
