Picture problems with DVI
Discussion in 'TAG McLaren Audio Owners' Forum' started by Londonrich, Jan 30, 2005.
  1. Londonrich
    Londonrich
    I have a AV32DP, DVD32R with PSM module. I am running the DVI from the DVD32 to a Marantz12S3 DLP projector (which is great). For some dvds the picture is off center - ie a third of the picture missing. This does not happen with all dvds and sometimes it only happens with the extras not the main picture.
    I am not clear whether this is a Marantz issue or a Tag setting.
    I have no problems with the picture in normal s-video mode.
    I would appreciate any help.
  2. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    I get exactly this too, had to centre up the image by altering the input file....Not sure you can do that on a marrantz... I think it is something to do with the menu's being 4:3 (and possibly NTSC not PAL!!!!) and the PSM gets all confused.....The main feature was always right though..... I gave up with the DVI output and used the component ones, better picture anyway..... Your particular Marrantz is quite a stroppy beast with HDCP as well as I seem to remember.....
    Have you tried the setting for always display 4:3 as 16:9 (by electronically adding the black bars)?
    If John or Steve want a demo disk the latest Rod Stewart (one night only at the RAH) shows it perfectly.....
