Picture Problems with a DVI
Discussion in 'Projectors, Screens & Video Processors' started by abspag, May 25, 2005.
  1. abspag
    abspag
    :confused: I have been having a lot of
    trouble with losing the picture or a big black line through one third of
    the on screen picture on a DVI feed to a Screenplay 8405 from a Tag Mclaren DVD. After testing of the projector and the
    DVD into other display devices and using different connections i.e.
    s-video and component they all work fine. I have discovered that if I
    disconnect the DVI cable then reconnect it the picture comes through
    fine. However the problem now is that to get a pure digital DVI feed I
    need to connect and reconnect the DVI lead at the DVD player every time
    I want to watch a movie. This leads me to think that either the PSM DVI
    out is faulty or the lead is faulty. Due to the fact that the DVD is
    perfect on all other connections I am almost sure that the problem lies
    with a faulty DVI lead at the termination point (if I wiggle carefully
    the picture comes back). Has anyone got any ideas or thoughts before I rerun a new cable The dvi cable is 8 metres
