picture problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by chris the dev, Jan 22, 2005.
  1. chris the dev
    chris the dev
    I have connected all the equipment up as advised earlier - (TV, SKYBox, VCR, DVD-R) I can now play DVD's via AV1.
    BUT - when I now plug in my camcorder, via my s-video cable, the picture doesn't appear on the TV screen on 'any' channel!!
    Any ideas?!
    Chris D.
  2. Timbo21
    Timbo21
    Dec 23, 2004
    4,473
    3
    2
    London
    +263
    The s-video won't appear on any 'channel' it should be a matter of switching
    to the appropriate input like you would for scart input. Also, you might have to look at the input setup in the menus which might give you a choice between say RGB scart input or s-video when using a particular line.
  3. chris the dev
    chris the dev
    Timbo,
    Thanks for the reply.
    I have gone through all the channels and it doesn't appear 'anywhere', whereas it did before.
    I have also found that my TV - perhaps through age - doesn't seem to have/cope with RGB. It only works on PAL. Will that make a difference to your suggestion?
    Chris D.
  4. jem
    jem
    Sep 24, 2002
    527
    +7
    Are you plugging the camcorder into the TV or the DVDR?
  5. chris the dev
    chris the dev
    I'm plugging the camcorder directly into the DVD-R. (No other equipent ha an s-video plug-in).
    Ta
  6. jem
    jem
    Sep 24, 2002
    527
    +7
    So can you look on the s-video socket or in the manual for the AV number associated with this socket?
  7. chris the dev
    chris the dev
    So I have to look at the socket on the DVD-R for an AV number, or in the DVD-R manual? Sorry, this is all new to me!
    I'm really sorry, but I have to head off to work now! I'll have a look at those tomorrow, and perhaps we could pick up this thread then?
    Chris D
  8. jem
    jem
    Sep 24, 2002
    527
    +7
    I've just had a look at the manual for your DVDR online.
    From what I can see you plug your camcorder into AV4 on the front panel. This should automatically select AV4 on your DVDR as its input - does it not do this? Presumably you are using AV1 on the TV to view this?
    If it does not automatically select AV4 on your DVDR then manually select AV4 as your input channel on the DVDR.
  9. chris the dev
    chris the dev
    Hi Jem,
    Unfortunately the AV4 input is for DV. My camcorder is not fully digital therefore I am using the s-video cable.
    Chris D.
  10. jem
    jem
    Sep 24, 2002
    527
    +7
    Have you found the AV number of the S-Video connection?
  11. chris the dev
    chris the dev
    Just popping out to do a collection from the train station!
    No I haven't - will do that and get back on the site asap.
    Chris D.
