Picture of a PW7 side on, mounted on wall bracket.
Discussion in 'Home Cinema Buying & Building' started by Alexg, Mar 13, 2005.
  1. Alexg
    Alexg
    Aug 7, 2001
    234
    16
    Looking through the "get your plasmas out for the lads" pictures I can't find one of a Panny PW7 side on. I would like to see how it looks when looking bang side on to see whats it looks like as you will see this side as you walk in the room.
  2. Stuart.Ainslie
    Stuart.Ainslie
    Nov 20, 2004
    119
    16
    Little Clacton, Essex
    Like this......
  3. dazed&confused
    dazed&confused
    Mar 12, 2005
    550
    Kettering, Northants
    +31
    That's really useful, thanks, 'cos I'm looking to have the same set-up.
    Could you tell me 1) is this using the R100 wall mount? and 2) how much does the front of the screen actually stick out from the wall?
    Thanks.
  4. Stuart.Ainslie
    Stuart.Ainslie
    Nov 20, 2004
    119
    16
    I'm using the AV-Sales tilting mount.
    110mm from wall to front of panel.
