Picture not in centre
Discussion in 'Blu-ray & DVD Players & Recorders' started by Odbod, Jul 10, 2005.
  1. Odbod
    Odbod
    May 15, 2005
    45
    11
    Fareham
    I have recently purchased a Samsung DVD850 but after running the THX optimizer (using The Incredibles), I have noticed that the picture is slightly high and to the right. It is more noticeable when watching a 2.35:1 ratio film than a 1.85:1 film, as the bottom black bar is significantly thicker than the top.
    There doesn't appear to be anything on the player or on my TV (Panasonic 28" CRT model) that will fix this. By the way, I am running it through a scart lead and RGB.
    Prior to this I had a Wharfedale M5 and this was slightly off centre also in that it was low and to the right, although the black bars did seem to be even.
    I also watched Welcome To The Jungle on Sky+ last night and again, the black bars seemed even.
    Is this a known problem with DVD players, does anyone else have this happening or is there something wrong with the Samsung (or indeed the TV)?
    Any advice would be appreciated.
  2. Mark_a
    Mark_a
    May 27, 2005
    3,026
    +593
    To adjust your picture for centre I think you might need to get into the service menu. I've no idea how you do that on your particular TV, though, sorry.
    Regards
    Mark
  3. Odbod
    Odbod
    May 15, 2005
    45
    11
    Fareham
    Actually, your response sent me off in the right direction and after a bit of searching, I managed to find out how to get to the service menu. I have now adjusted the height and width and everything looks great.
    Thanks.
