Picture in Picture
Discussion in 'Plasma TVs' started by monocle, Jun 16, 2003.
  1. monocle
    monocle
    Anyone else with an LG MZ-42PZ14 or similar...........Is there something special I have to do to get PIP to work? I do have the tuner and I don't see anything in the manual or on the LG website to help. Cheersums
  2. mikeblanche
    mikeblanche
    I think it's a case of RTFM - on my PZ17 you can have PIP between two different sources (e.g. RGB and composite), so if you have the tuner you can't watch two different TV channels at the same time (because it's not a twin-tuner tuner if you see what I mean)
    I haven't actually used the PIP feature as I only use one input at a time, but that's what I recall from reading the manual.
    There are manuals on www.lgelectronics.co.uk
    Mike
