Picture in picture
Discussion in 'General TV Discussions Forum' started by jcan, Jul 21, 2002.
  1. jcan
    jcan
    Does anyone know how the Picture In Picture facility available with Sony FX66 models actually works and what sort of functionality it provides? It says it has a single tuner? I can understand how the FQ series would do it having 2 tuners, but how is it done with 1?
  2. Christ
    Christ
    Dec 15, 2002
    275
    Yorkshire
    +18
    It uses the tuner from another source (i.e. Video/Sat/DVD) for the
    second picture
  3. MadAxeMan
    MadAxeMan
    I'm going to buy the FX66 soon - need to clarify how the PiP works though...
    ...anyone explain fully what you can display in the PiP??? The guy in Comet reckons only the main picture, which is obviously BS.
    Can I have analgoue in the main picture and any AV source in the PiP and vice versa???
    Cheers.
  4. Garrett
    Garrett
    Apr 21, 2001
    42,088
    2
    167
    The best thief you'll never see.
    +7,632
    Two years ago I was looking into buying a new set and at the time no set only the Loewe had PiP(also PaP). They had all switched to PaP. Picture and Picture. Have they gone back to using Picture and Picture?
  5. Christ
    Christ
    Dec 15, 2002
    275
    Yorkshire
    +18
    Jcan
    All it means is that whilst watching from one source (say TV through aerial) you can view any second source in any corner of the screen (with the sound through headphone socket), the input to this can be TV/SAT/VIDEO/DVD. Probably not something you would use every day but it is occasionally handy..
    Chris
  6. MadAxeMan
    MadAxeMan
    Cheers, that's the kinda thing I want.
    Like you say not something you'll use everyday but handy none the less.
  7. TommyP
    TommyP
    Nov 7, 2002
    63
    Maidenhead, Berkshire
    I found the best use was when your going to record one thing and watch another you can have a picture of whats going to be recorded in the corner and get the right point when it starts rather than having to keep flipping back and forth.
    Also good for finding out when ad breaks have finished.
    If anyone wants I can take a piccy to show the PiP working?
  8. MadAxeMan
    MadAxeMan
    Yep, that would be cool :D
    Also, how does it work on the remote - is it easy to flip between sources...
  9. ryanos
    ryanos
    Nov 17, 2002
    266
    +3
    Yes there is a button on the remote which lets you switch between pictures
  10. w3dal
    w3dal
    Aug 4, 2002
    5,055
    Chelmsford, Essex
    +589
    I was playing the PS2 yesterday, whilst watching the Spurs game using the PIP option on my FX66.
    Not something i use very often but does come in handy everyonce and a while, this TV does have some great features!!
    I also used the remote finder for the first time yesterday, an excellent feature and should be on all TV's
    Dal :rolleyes:
