Picture hanging when viewing avi movies
Discussion in 'Desktop & Laptop Computers Forum' started by benwi, Jul 8, 2002.
  1. benwi
    benwi
    I have some problem with my HTPC. When I look at a avi movie the picture sometimes hangs but the sounds goes on. The only thing I can do then is to stop the movie and then start it up again. I have a AMD Duron 800MHz, 128MB RAM and a GeForce2 MX 200. I have used Media Player, Zoomplayer and Power DVD but it is the same with all of them. I have installed the latest codecs by installing Nimo Codec Pack (http://www.nivelvirtual.net/nimo/).
    Has anyone experienced this and, if so, how have you solved the problem?
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Try the latest Divx5 codec install.
    Get it here
    Version is 5.0.2
    It might sort out your problem, but I've found that if it needs this codec then you don't get a picture at all.
    Worth a try though.
