mac_monkey
Established Member
Just moved into a new house so I thought I'd order some prints from snapfish to put on the wall, but I'm having difficulty locating frames.
The photos are all of my 8 month daughter. There's one high key B&W, one low key B&W and one with desaturated colour (almost high key) all 12" x 8" landscape.
Ideally I want to use a black, wide frame with a white mount for the "gallery" look.
A couple of questions:
1. If the photos are 12*8 what size frame should I get to incorporate the mount. I was thinking + 2" all around therefore 14*10?
2. Can you recommend any frame retailers?
3. Should I get the mount separately?
4. Any other advice?
Thanks in advance
Tom
Thanks in advance
Tom
