Picture Edges
Discussion in 'General TV Discussions Forum' started by Mole69, Oct 18, 2004.
  1. Mole69
    Mole69
    I have a JVC AV-28x4 TV, it's only 3 months old. I am experiencing a strange and irritating symptom.
    Down each side of the screen, there is a slight pattern, a bit like faint vertical pin stripes down the screen. The best way I can describe it is it's as if the density of the pixels or the resolution of the picture graduates away as it nears the edges of the screen. It is present on any source I select and regardless of the TV's Zoom setting. I thought it may have been the Panoramic setting, which as I understand it, maintains proper aspect ratio in the centre of the screen, and stretches it the further towards the edges you get. But whichever picture format setting I use, the problem is still there. Any suggestions?
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,425
    Somewhere in South Yorkshire
    +5,824
    I think you are describing a design feature of the tube. I have seen this (if I understand you correctly) on large, flat-screen CRT TVs with Panasonic tubes.
  3. Zaichik
    Zaichik
    Mar 5, 2002
    1,541
    116
    +604
    All three of the Panny TVs I've had have had this. When I saw it the first time, I put it down as a fault and pushed the retailer for an exchange but I wish I hadn't now. All the subsequent replacement sets have been the same but have had some other fault to boot.
    Most of the 28" TVs in my local store seemed to exhibit the problem to some extent, but the 32" sets didn't (or not that I could see). I've just accepted it now - I just hope that the 4th set that I'm getting this weekend has no other problems.
