Picture Comparison Software wanted - Help Please!
Discussion in 'General Chat' started by PoochJD, May 21, 2005.
  1. PoochJD
    PoochJD
    Aug 28, 2000
    10,992
    Norwich
    +1,862
    I'm hoping that someone on here can help me out please. Basically, I'm looking to find out if you can get some freeware or shareware software (suitable for Windows XP), that will allow you to compare two images side-by-side, to see if they are the same, and/or if there is any difference in image size or quality.
    I often download pictures from the Net, but it's not easy to always know if I have a ceertain image or not, and with over 1200, I don't want to keep having to go through each one, to see whether or not I already have it.
    Does anyone have any ideas, please?
    Pooch
  2. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,349
    83
    +193
    You could use something like Clone Master to eliminate duplicates.
    I don't know of any software that does what you're asking (believe me - if there were one that was decent, in my job it'd be a godsend) because of compression, size, algorithms etc.
  3. PoochJD
    PoochJD
    Aug 28, 2000
    10,992
    Norwich
    +1,862
    Hi Sadmuppet,
    Thanks for that. I'll give it a go. :) Just out of curiosity, what "line of work" are you in?
    Pooch
    P.S. I've just found this advert that might help both of us out! :thumbsup: Click here! :smashin:
