Picture breakup on C4 - via sky plus
Discussion in 'Sky Digital TV Forum' started by MarkTy, Jul 19, 2005.
  1. MarkTy
    MarkTy
    May 20, 2005
    163
    16
    Hi there
    I'm having a lot of reception problems on C4 via my Sky plus box.......no other channels are affected at all.
    Every few seconds major pixelisation, and eventual freeze...switch to another channel and no probs at all....back to C4 same problem
    Any ideas anyone....the cricket starts Thursday !!!!!!
  2. paulfoley
    paulfoley
    Sep 17, 2003
    3,549
    Hants
    +114
    Theres a big thread about this over at digitalspy. Until Sky sort it you need to view channel 964 (much better but not perfect).
    Hope this helps !
    :smashin:
  3. woollyjumper
    woollyjumper
    I get big blocks of picture and loss of sound temporarily. Is it from Outside broadcasts when you get it - or also when watching general programs ?
    Rang up Sky and told me to do the usual - switch off, disconnect and re-connect - still happens occasionally.
    I will let you know if it continues to happen.
  4. paulfoley
    paulfoley
    Sep 17, 2003
    3,549
    Hants
    +114
    Yep picture breakup, sound dropouts & freezing. It happens on all programmes. Ring Sky again & tell them it is not just you, theres loads if us, point them to the long thread on DigitalSpy & they might actually do something !
    Good luck !
    :cool:
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    It's nothing to do with Sky - it's a Channel 4 problem, you need to ring them.
