Pics Of Your Stands !
mug
I thought it would be a good idea for everyone to post a picture of their stands and where they got it from. Maybe its just me but when I'm interested in a stand I'd prefer to see what it looks like when it has a TV on it. I think this thread would be good for potential buyers and also might get to see some stands they've never seen before.
Thanks,
Marcus
smokedog
Good idea but where's your stand photo?
I'll start the ball rolling
Vistron 2 Tier Cantilever
http://www.ebuyer.com/product/131624
Slightly modified the back to put cables through
Knightshade
Here's mine, and another one. The open stand has a 42", the Oak cabinets has a 50" with MA radius speakers, the lower left cabinet houses the sub, the right has the players and amps. The rest is full of kiddie stuff.
Aleem
Established Member
Thanks,
Marcus
Can I suggest that people state the size/model of screen which would be useful when trying to visualise your own set-up with stands in the pics.
Cheers.
Great pics so far by the way.
Ewoody
mug
This thread was a cheeky way to look other peoples stands. Maybe further along when I've decided I'll post my own pic :hiya:
Rottie
Established Member
doodles
Established Member
whats the difference between 1/2 or 3 tiers, is it just looks or??
i have a samsing 37in lcd tv, will any of these style stands fit on mine or all tv's got different connections/fixings??
thanks
Rottie
Established Member
thanks
Hi there,
The reason I wanted a 3 tier version, is because I have a lot of stuff to go into the stand, namely a Denon AV amp, XBox 360 Elite + HD DVD addon, Pace Sky box (soon to be replaced with a freesat box) and the centre speaker.
If I wanted to cram all of that kit into a 2 tier stand, it would literally have to be shoehorned in, which would not help the airflow any. :(
WRT to your 37" TV, give Samsung a call on 01932 454358 and tell them which model you have. They should then be able to tell you what size VESA mount you need for your TV and more importantly, the correct size screws you need to use to fix your TV to the mount.
For example, in my instance, with a 32" LE32A436T1D, I'd need a 200x200 VESA mount and the screws I'd need are M6L10.
Hope this helps.
bigfecker
Established Member
Hi there,
Hope this helps.
I'd also like a 3 tier version, but looks like the manufacturer does not make one :(
just found this:
http://www.amazon.co.uk/Techlink-Avatar-PTV3-Designer-Plasma/dp/B00177XA48/ref=pd_sbs_ce_img_44
malk
heres mine,Techlink bench,v+, teac 550(waiting for 606 STILL),ps3 60gb toshiba 37wlt68.
Rottie
Established Member
Rottie
Established Member
Rottie
Established Member
paulg1979
Established Member
Heres mine. Just bought a new Panny Plasma so i'm going to have to get rid of this
🎬 The Top 20 Most Anticipated Movies of 2024
Back
