picking up a 9607 on Sunday... YES
Discussion in 'General TV Discussions Forum' started by jimmylad, Jul 12, 2002.
  1. jimmylad
    jimmylad
    At last !! I've finally decided after weeks of looking & browsing that the best overall option for me will be the 9607. The posts on here made all the difference. I thank you all.
    I wanted a 42" or bigger RPTV but at the end of the day the "tube" won due to it's superb image & if i want the TV to appear bigger I'll just have to push the setee up a couple of feet.
    So......... just a few questions to current 9607 owners if you don't mind.
    1) Is the sound good enough without having to "beef" it up ?
    2) I will need a DVD player (£170 ish) & finally........
    3) Which is the best way to connect it all up ( Sky digital, DVD,
    & video)
    Thanks to everyone
    Jim
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    1. Good enough??? Well it sounds good to me and certainly beats any other integrated system. Obviously if you have spare money :D then by all means splash out!
    2. If you don't think it sounds too cheap I can heartily recommend the Cyberhome AD-L528... only £99.99 from Richer Sounds will play all regions out of the box including RCE titles without modification. Has a remote control macrovision hack, component, rgb, composite and s-video out along with both co-ax and optical out for sound. It will also play VCDs SVCDs CDs and MP3 CDs too! Oh and the picture is fantastic!
    3. I have DVD connected RGB + coax to EXT1. Sky RGB to EXT 2 and Composite to my video and Video composite to EXT3
    Enjoy your new TV!
  3. jimmylad
    jimmylad
    dvd sound excellent. will look into it.
  4. Adrian
    Adrian
    Jul 17, 2002
    12
    4
    West Sussex
    Would be grateful for some advice...
    My 9607 works perfectly but with pre-recorded VHS tapes..
    When I play pre-recorded VHS tapes, original , new , digitaly mastered, etc.., I get vertical lines on the sides and generally a "rainy" screen...I cannot get rid of these whatever input I use...
    Strangely, this does not happen when recording fromn the TV and playing back the tape..
    Any ideas ? Adrian
