Picked up my new car... problem.
Discussion in 'Motoring' started by GrumpyOldGamer, Aug 1, 2017.
Tags:
  1. GrumpyOldGamer
    GrumpyOldGamer
    Sep 8, 2013
    1,392
    116
    +772
    I say new it's a 2015 VW Passat GT 2.0tdi covered 14,000 miles and bought from VW.
    When the car gets hot at around 1.5 to 2.5 on the rev range as you cycle through the gears there's a noticeable vibration noise under load, doesn't do it if you just rev the engine, has anyone experienced anything similar?
    Really trying to avoid taking it back as it's a two hour round trip!
  2. un1eash
    un1eash
    Nov 14, 2007
    5,029
    2
    +1,449
    Its under manufacturers warranty so you can take it to your local vw dealership.
  3. GrumpyOldGamer
    GrumpyOldGamer
    Sep 8, 2013
    1,392
    116
    +772
    Yeah I know, but I also know how shocking my local Inchape VW is, il contact the place I got it from when it opens and go from there, they did explain the car had a 30 day or 1000 mile exchange policy, I hope it doesn't come to that though.
  4. lovegroova
    lovegroova
    Jul 15, 2002
    2,744
    103
    Herts
    +390
    Sounds like gearbox/clutch/dual mass flywheel.
  5. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    43,434
    11
    13
    167
    ::1/128
    +16,746
    Always start with the simple things. Do you have all wheel lug nuts tightly fitted ;)
    I was worried on my Audi A4 Quattro that I had some serious issue, then I noticed that one of the lug nuts was gone....Fitted another, tightened up all wheels and the car was smooth again...
  6. GrumpyOldGamer
    GrumpyOldGamer
    Sep 8, 2013
    1,392
    116
    +772
    No courtesy cars available so waiting to hear if they have a salesmans car to lend me then il drop mine off, just hope they find the issue, it's a lovely car besides the vibration noise.
  7. AMc
    AMc
    Nov 20, 2000
    7,573
    Near Norwich
    +4,309
    Similarly had a car which had weird vibrations under acceleration that disappeared or sometimes remained at speed.
    Turned out to be a loose wheel balance weight travelling around the rim :facepalm:
  8. GrumpyOldGamer
    GrumpyOldGamer
    Sep 8, 2013
    1,392
    116
    +772
    It was the heater pipes vibrating when they expand going through the bulk head, fixed by VW.
  9. IronGiant
    IronGiant
    Jun 7, 2003
    66,990
    +47,450
    You've just been spammed :D
  10. GrumpyOldGamer
    GrumpyOldGamer
    Sep 8, 2013
    1,392
    116
    +772
    I thought where's the post gone, now I look like a nutter for bringing an old topic back!
  11. IronGiant
    IronGiant
    Jun 7, 2003
    66,990
    +47,450
    Oh well, thanks for the update :)
