pick your brains on jvc-hd1
Discussion in 'Projectors, Screens & Video Processors' started by bign5, Jan 25, 2008.
  1. bign5
    bign5
    Apr 14, 2007
    193
    +5
    i am just setting up a room for a home cinema, i am hoping to get the HD1.
    2 questions if someone would be kind enough to answer them.
    is the power plug that goes into the back of the projector, the standard size kettle plug?, (if it is i will buy a longer one).
    as i can't see any mounting holes on the top of the projector, if i am ceiling mounting it, does it hang upside down? or does it need a cradle type mount?.
    thanks in advance
  2. Tony Hoyle
    Tony Hoyle
    Aug 4, 2005
    3,347
    103
    Stockport
    +231
    It's a standard kettle lead (IIRC.. only ever plugged it in once then left it). Mine is sat on a shelf (well, microwave bracket) so I haven't looked at mounting it, but generally PJs hang upside down when they're ceiling mounted.
  3. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,904
    UK.
    +3,382
    The HD1 has quite a range of lens shift, so you can even have it right way up above the top of the screen projecting down IIRC.
    Gary
  4. bign5
    bign5
    Apr 14, 2007
    193
    +5
    thanks for the quick answers, so i will just buy a long kettle lead, then thats the power sorted.
    i was wondering if it did work upside down, or if flipping it over messed up its airflow on the cooling?.
    need to figure this out, so i can buy a mount and get the painting of the ceiling done.
  5. Tony Hoyle
    Tony Hoyle
    Aug 4, 2005
    3,347
    103
    Stockport
    +231
    The HD1 has its vents on the front so it really doesn't care about top/bottom. It's got settings for inverting the screen for upside down use.
  6. Member 14847
    Member 14847
    Aug 16, 2002
    491
    28
    +54
    If you're buying the bracket before the projector then make sure you get one that fits (the Vogels PPC200 does but some SMS models need modifying).
