Piano or Screenplay 110????
Discussion in 'Projectors, Screens & Video Processors' started by kissakiwi, Mar 13, 2002.
  1. kissakiwi
    kissakiwi
    Hi all,
    Okay! Just when I *thought* I knew what I was doing/wanted, I went and did some more research and now seem to have two choices. Can I have some opinions on this matter?
    Seems the Screenplay 110 from Infocus has the same DLP chip as the Piano, but has the advantage of accepting 480p. It outputs 1000 ASNI instead of the Piano's 400. It also has a much longer lamp life. The Piano here in Europe is €3500 whereas the Screenplay 110 I have seen for €4500.
    I cannot for the life of me find anyone on the net who says a bad thing about the Piano, howver there is a LOT of people clawing to get hold of the Screenplay (esp. in UK!) Is it better than a Piano?
    What would you do?> Why?
    Cheers to all,
    Collin
  2. jrwood
    jrwood
