Physical screen height on wall?
Discussion in 'Projectors, Screens & Video Processors' started by Nic Rhodes, Aug 29, 2003.
  1. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    What height do you guys mount the bottom of your screens at?
    Nic
  2. rob_w
    rob_w
    Hi Nic,
    The bottom of my screen (visible area) is 38" above the floor.
    The screen is 72" x 40.5 " and the surround is 5" of dark blue velvet all round .
    hth
    Rob
  3. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    When I finally get my screen up again it will be approx 1m off the floor. This is to allow the speakers to go just under the screen, so as to be as close to the picture as possible before I can afford a sound screen.
    Like the recommendations for speaker positioning, there are recommendations for screen settings. I'm not sure what they are off the top of me head though.
  4. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    My screen is about 1 foot from the floor, the centre is about eye level.
    ::EDiT::
    I mean the centre of the screen, my centre is under the screen!
  5. chrisgeary
    chrisgeary
    Jul 23, 2003
    2,673
    Newbury
    +215
    mine is 70cm. below the screen i have the strata III and my centre channel on top of that. it seems about right, perhaps a smidge high for my living room. much lower, though, and i would struggle to see over the coffee table (enclosure), gotta have room for drinks too! :D
  6. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Thanks guys, anyone else?
  7. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Not crt..... but the bottom of mine is some 60cm from the floor. Previously i had it at just over a metre so i could get a centre on a proper stand, but it always felt as if i was un naturally having to look upwards.
    Ad
  8. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    I am thinking of 75
  9. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Id still be happy with that..... i would guess that having the bottom of screen above eye level would induce a creak in the neck..... so i guess it depends how big your sofa is and how long your neck is! :D
    What size are you hoping to go for Bee?
    Ad
  10. uncle eric
    uncle eric
    Nic,
    Whats your intended viewing distance?
  11. EvilMudge
    EvilMudge
    I too am looking at screen height. However with my current seating, you would be looking down at the screen even if it hung from the ceiling.
    Damn those stupid (possibly) over priced Futons...:clown:
  12. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    well I don't actually have one! I know this sounds daft but I have a screen, about to go on the wall, and the projector will go on the table. I will then sit in the best position behind the CRT. I will still have something like 15 feet behind me so I have loads of flexibility here to 'go for the best'.
  13. Miron
    Miron
    Sep 26, 2002
    1,435
    Vienna, Austria
    +54
    Dominic, maybe stupid advice but it is better to start with lower position, and then rise it up if not satisfied. It can be pain in the ... to set PJ again (if you can not lift up the table) but at least the holes on the wall will not be seen afterwards (when the light is on)
    I saw some screens hanging suprisingly low and must say I liked it.
    Also think good about placing of the centre speaker. I saw quite a few touching the bottom of the screen and never liked it :(
    Have fun!
    Add On:
    One guy I trust a lot when it comes to Home Cinema (he build his own HC over five years ago) told me this:
    The best way is to reduce the lights to the minimum, just to see where the fronts are, and then sit on your place for about half and hour watch into the front wall. The place you find most pleasent to look into after half an hour should be one third from the bottom of the screen. So he did and it turned out to be great room!
  14. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    I always work to this calculation
    The bottom of the screen should be 1/3 of the screen hieght down from the eye level of seated possition of the viewer.
    This should work for any viewing distance and any screen size.
  15. martintyler
    martintyler
    Sep 28, 2002
    120
    19
    London
    Would you say this can effect the quality of the picture due to the angle of the reflected light.. or is it purely about comfort of the viewer?
    I have the bottom of my plasma slightly above eye level and dont agree that this is a problem at all with comfort.. people that say it is have often never tried it.
    I am thinking about getting a projector and the bottom of the screen would be at eye level - this means my front three speakers can stay where they are.
  16. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Thanks guys
