Photoshop slowing up
Discussion in 'Photography Forums' started by jaymac, Oct 13, 2003.
  1. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    After several sessions on photoshop iit starts to slow right down ie all moves or actions take ages. Icanget round this by restarting photoshop and holding cntl alt shift and resetting files. but does anyone Know what causes it and how to prevent it
  2. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    I recall reading that you should move the scratchpad (ie paging file) to a different disk partition to improve performance.
    Don't know if this is the cause though. I am not getting this problem on my system.
    Seems like a memory problem though. Have you checked the settings for the undo history etc?
    woody
  3. tomson
    tomson
    Jul 19, 2000
    1,918
    Berk'amsted
    +187
    Pretty much as woody67 has mentioned above... the usual culprits are lack of hard disk space for the scratch disk (move it (via preferences) to another disk or make sure you have at least a few gigabytes spare), lack of physical ram (go for as much as you can afford) and your machine getting bogged down with stored history (purge it regularly). Also make sure you've got the latest updates from adobe.com.
    Are you working with big or hi res files?
  4. sweetmate
    sweetmate
    Aug 29, 2001
    695
    London
    +46
    Its the only problem I have with Photoshop - Its memory usage.
    The way it works, is that it will use memory available up to the % of system ram that you specify and then once it reaches that, it has to start using the HD, which is much much slower. Now the problem is, every time you open a file and manipulate it, photshops memory usage goes up accordingly, but then when you close that file, photoshop keeps the memory for itself and doesnt give it back to the OS. So if you work on a bunch of files and then hit the limit of your ram, from then on photohop will be sluggish. Only fix is to restart photoshop.
  5. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    Thanks for all your input Ihave about 2 gigs spare but it looks like the memory usage method could be the problem. I do work with big/hires files but this doesn.t;bother paint shop pro thanks again
