Photoshop dudes please.....
Discussion in 'Photography Forums' started by Chubster, Jan 7, 2012.
  1. Chubster
    Chubster
    Nov 16, 2008
    1,746
    63
    Haslemere
    +149
  2. RobDickinson
    RobDickinson
    Mar 8, 2001
    4,756
    Christchurch , New Zealand
    +748
    Use selection tools to select a large area round it but not the dog.
    So you now have say a big circular loop around it but a perfect line along the dogs neck/head/ears.
    This will prevent you from cloning outside of that selection.
    Use the clone tool select somewhere then clone it out, start at the top work down.
  3. Liquid101
    Liquid101
    Jan 30, 2006
    8,028
    Aberystwyth
    +3,073
    As an alternative, you could make a duplicate layer of the whole canvas, use the clone tool to cover the offending area without worrying about covering the dog elements. Reduce the opacity of the layer, so the original image shows through then use the eraser tool tool at 100% to remove the parts where you went over the outline of the dog.
    That way you always have the option to undo, or redo parts which you're not happy with, and use softer edged tools to help with blending etc.
  4. BubbleDouble
    BubbleDouble
    Jan 13, 2009
    4,227
    2
    Space
    +1,883
    That's how I'd do it :smashin:
    Darren
  5. cedmondson
    cedmondson
    Nov 27, 2005
    1,130
    83
    Basingstoke
    +283
    A variant on Liquid101's technique would be to add a layer mask to the top layer, and instead of erasing through the pixels of the top layer, paint in black on the mask. This has the same effect as erasing and you can still undo / redo & control brush hardness etc. The advantage is that you can also paint in white on the mask to 'unerase', so you can continue to tweak your selection after history is lost and no pixel information on either layer is lost.
  6. GaseousClay
    GaseousClay
    Jan 11, 2011
    5,902
    UK
    +7,527
    As cedmondson says, use layer mask. Three minute job. ;)
