Photoshop 7.0.1 Upgrade?
Discussion in 'Photography Forums' started by Paden, Jul 17, 2003.
  1. Paden
    Paden
    Jul 27, 2000
    553
    +13
    Has anyone downloaded the .1 upgrade for version 7?
    I got it ok but when I try to install it's "unable to find Adobe Photoshop 7.0 in C:\Program Files \Adobe\Photoshop 7.0\" but that is exactly where it is :confused:
    Any suggestion?
    Cheers, Paul
  2. nathan_silly
    nathan_silly
    Does the same on mine too...
  3. Paden
    Paden
    Jul 27, 2000
    553
    +13
  4. m@rk
    m@rk
    Jan 3, 2002
    1,212
    83
    Lincolnshire
    +360
    Speak with Adobe
    The upgrade checks your serial number against a list of know serials that have been distributed on the net and used for illegal copies.
    Assuming that your copy is 100% legal, then Adobe will issue you with a new serial number which will stop this happening.
  5. Paden
    Paden
    Jul 27, 2000
    553
    +13
    Don't think I'll be contacting Adobe just yet :blush:
    Cheers, Paul
  6. m@rk
    m@rk
    Jan 3, 2002
    1,212
    83
    Lincolnshire
    +360
    Don't you just hate it when that happens :nono:
