Photos of your wall-mounted LG RZ42PX11.....
Discussion in 'Home Cinema Buying & Building' started by Daipac, Apr 19, 2005.
  1. Daipac
    Daipac
    Apr 12, 2005
    659
    +12
    I know a lot of you have the LG and I was hoping that you could post photos of your RZ42PX11 mounted on the wall.
    Only 6 days till I get mine ! Not that I am counting or anything !
    :rotfl:
  2. Daipac
    Daipac
    Apr 12, 2005
    659
    +12
    Don't be shy ! Come on...........
    :D
  3. Daddy k
    Daddy k
    Jul 19, 2004
    9,081
    coventry
    +1,345
    heres mine mate allthough i cheated, its not wall mounted its placed on the fireplace lol and kept tight2the wall with the 2 lil brackets inc with panel to prevent it topling
    dont worry iv tried pulling it off the wall/fireplace, it wont budge,
    a good benefit of wall mounting is if godforgives we get burgled it wont half p*ss the crims off when they try to take the panel etc lol
  4. mh123
    mh123
    Apr 2, 2005
    694
    Offshore UK
    +71
    Yeah but knowing your typical thieving scumbag, they'll either rip it from the wall anyway or stick an ornament through it for the sheer hell of it.
    Happened to a mate of mine - he was burgled and it was obviously one guy so his 50" Pio was a bit too much to carry(!) - so the scroat stuffed a carriage clock in the front and totalled it!! :suicide: Luckily he'd had the plasma put on his insurance as a specifically named item, and the time lag between claiming for the loss and receiving the cheque meant that after he'd replaced it he was about £500 up on the deal!
  5. zorg
    zorg
    heres mine :D
      Size:
      57.2 KB
      1,087
  6. Daipac
    Daipac
    Apr 12, 2005
    659
    +12
    zorg, that looks awesome ! What mount did you use ?
  7. kocl
    kocl
    Jan 8, 2003
    602
    PORTUGAL
    +14
  8. Daipac
    Daipac
    Apr 12, 2005
    659
    +12
    Looks great kocl !
    The LG does look really good on the wall IMHO.
    Cannot wait to get mine now ! The wall mount arrived yesterday but I have to decorate my bedroom before I can put it on the wall. Better make a start on the weekend I think ! LOL !
    Keep 'em coming guys and gals !
  9. lawrenso
    lawrenso
    Oct 6, 2003
    1,185
    48
    Flintshire
    +35
    Never mind the mount - where did you hide the cables - damn fine job there. :smashin:
    Is it a stud, solid or dot and dab wall it is on??
    Lawrenso
  10. zorg
    zorg
    hi guys, its mounted with a narrow (thin depth) rs100 bracket, which holds it about 40 mil from the wall, i have a scart in there as well (even though they say you need the extention bars for this) and component-in from my playstation (the pic you see is from my ps2)not a bad pic :thumbsup:
    its a stud wall and i used coach bolts for the stud points and cavity wall fixers for the rest, it took my weight no problem and holds the screen effortlessly. the cables are routed a "special" way :smashin: i'll take more pics when i get time
    cheers
    zorg
  11. zorg
    zorg
    ok heres a pic of the rs100 bracket, pretty slim i think you'll agree.
    and here is how i routed the cables. these are black plastic handles from maplin priced 99p each, i think they are for making your own p.a. system e.g. handles for the side of your huge speakers or something. i have one mounted behind the screen pointing downwards and this one at the bottom of the wall pointing up. i cut a hole in the back of the hanle to allow the cables to pass through, if your worried about draughts then a piece of foam can be wedged inside. i think this must be the cheapest and neatest solution i have seen. this will be hidden be my shelves that i will be building once i get my finger out
    cheers
    zorg
    edit* heres a link------ http://www.maplin.co.uk/Module.aspx?ModuleNo=1885&TabID=1&source=15&WorldID=&doy=23m4
  12. Daipac
    Daipac
    Apr 12, 2005
    659
    +12
    zorg, that looks quality ! Absolute quality ! Really like that !
    I take it you are happy with the LG then ?
  13. Daddy k
    Daddy k
    Jul 19, 2004
    9,081
    coventry
    +1,345
    redecorated so thought id repost my lg
  14. simon33
    simon33
    I love the circles - is that wallpaper?
  15. Daipac
    Daipac
    Apr 12, 2005
    659
    +12
    krismc, that looks cracking mate ! Really nice !
    Finally going to finish decorating tonight so I hope to have a photo of my own wall mounted LG tomorrow !
  16. Daddy k
    Daddy k
    Jul 19, 2004
    9,081
    coventry
    +1,345
    cheers, yeah its wallpaper from b&q but its just discontinued so i got it half price, was supposed to be £20 a roll :eek:
    theres a few left if you pop into there and ask where they have remaining stock
  17. zorg
    zorg
    for the money i dont think you can get better, i do get colour banding which does **** me off a little but i'm willing to put up with it for the cost, my anus isn't as tight as some on here ;)
    no one else notices it, the menus are pretty easy to follow too.
    i recommend this screen to anyone.
    zorg
  18. jondarren
    jondarren
    Hi there all,
    I'm new to the forums and have just purchased the latest LG 42PX4RV plasma. I'm in the process of deciding how to wall mount and whether to build a stud wall from Gyprock or to create a blanking panel to hide the wires. Would anyone have any suggestions for the best, or easiest way to do this?
    Jon..........
