Photographing Oil Paintings
Discussion in 'Photography Forums' started by topgazza, Jan 30, 2014.
  1. topgazza
    topgazza
    Sep 3, 2006
    14,418
    Near Basingstoke
    +3,581
    I want to take some pictures of my daughters paintings as people have been asking for prints. Being oils they reflect any pre focus light and can be tricky to get the right angle and light to take a good picture.
    I don't have any professional lighting gear but any advice appreciated
  2. eddiewood
    eddiewood
    Dec 11, 2007
    6,724
    +1,145
    Have you got a CP filter to try?
  3. topgazza
    topgazza
    Sep 3, 2006
    14,418
    Near Basingstoke
    +3,581
    Thought about that to cut reflections... I'll give that a go. Was thinking about outside in this dull weather as well
  4. shotokan101
    shotokan101
    Jun 16, 2009
    75,582
    25
    Glasgow
    +25,573
    • Like Like x 1
    • Thanks Thanks x 1
    • List
  5. topgazza
    topgazza
    Sep 3, 2006
    14,418
    Near Basingstoke
    +3,581
    I looked at both of those Jim but thanks for pointing them out. Didn't think there was any magical easy way to do it. I'll give it a go
  6. shotokan101
    shotokan101
    Jun 16, 2009
    75,582
    25
    Glasgow
    +25,573
    It really depends how detailed a capture you want I guess but I can see the logic behind that lighting suggestion for paintings - especially anything the least bit reflective...
  7. topgazza
    topgazza
    Sep 3, 2006
    14,418
    Near Basingstoke
    +3,581
    Someone suggested taking the picture outside on an overcast day and use a CP. I'll give that a try. Not actually taken a photo of the picture yet so not sure how reflective it will be and prone to any stray light
  8. shotokan101
    shotokan101
    Jun 16, 2009
    75,582
    25
    Glasgow
    +25,573
    worth a try and I saw that suggestion and I thought that someone had tried it not too successfully though I don't remember if the used a CPL or not....
  9. topgazza
    topgazza
    Sep 3, 2006
    14,418
    Near Basingstoke
    +3,581
    I'll post back when I've done it.
  10. Some Bloke
    Some Bloke
    Nov 19, 2007
    2,124
    116
    +571
    If you have to use flash make sure it's off the camera.
    Personally, I'd use ambient light. And won't bother with any filters.
    Also make sure you white balance the shot, so the colours in the photo match the painting.
    Set your lens to its sharpest aperture and obviously use a tripod.
  11. topgazza
    topgazza
    Sep 3, 2006
    14,418
    Near Basingstoke
    +3,581
    Good point about the white balance. I can always adjust in PP but a benefit to get it as close as possible in camera for sure
  12. topgazza
    topgazza
    Sep 3, 2006
    14,418
    Near Basingstoke
    +3,581
    I think it came out alright in the end... no filters in doors with no direct sunlight so fairly even light all round. Exp Comp @ -7. Actual image size is 60cm x 60cm. I've used Elements to add another 3cm around the edges on the final version for Jessops to allow for printing on a canvas without losing the badge or any of the image as you see it here
    [​IMG]
  13. shotokan101
    shotokan101
    Jun 16, 2009
    75,582
    25
    Glasgow
    +25,573
    Looks really quite "flat" Gazza - though to seeing the original obviously doesn't help :D - but if memory serves me right the actual album cover was pretty bland as well ?
  14. topgazza
    topgazza
    Sep 3, 2006
    14,418
    Near Basingstoke
    +3,581
    The album cover looks a pretty rough surface as it was created that way to look like rough parchment. Obviously Kate couldn't recreate that effect so the overall painting is just oils on canvas. Hence a little flat in comparison but thats OK it stills looks astonishing
