Photographing an LCD and CRT
Discussion in 'LCD & LED LCD TVs Forum' started by iendicott, Mar 17, 2006.
Tags:
  1. iendicott
    iendicott
    May 3, 2005
    268
    Peterborough
    +5
    OK sounds a little odd but when I photograph a CRT screen that is on the camera catches an image with a massive black line down half the screen but on this forum many people have photographed their LCD screens with a very clear picture, I take it that the CRT is running in interlaced mode and that is what the camera is picking up ?
  2. Whappers
    Whappers
    Dec 28, 2005
    305
    Belfast
    I'm not sure but I believe it is just the flicker from the refesh rate:confused:
  3. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
    What your're seeing on the CRT is the actual scan lines because of the interlaced picture, whereas an LCD outputs a progressive picture, so you see the complete image.
  4. RockySpieler
    RockySpieler
    May 23, 2005
    1,661
    Snaking the Lineup
    +115
    You could try experimenting with 1/25 or 1/20 shutter speeds, this may capture both interlaced frames............just keep your hands steady!!!!
