Photo numbering
Discussion in 'Photography Forums' started by alj23, Aug 23, 2013.
  1. alj23
    alj23
    Nov 9, 2006
    227
    +12
    Hi - I have had a quick search but can't seem to find anything -
    I am doing a lot of photography for friends at the moment and shoot with a Canon 40D and 450D - I have seven different memory cards and am not sure whether to reset the file numbering each time I do a shoot or to leave it to keep counting ?
    What does everyone else do ?
    Thanks in advance
    AJ
  2. Sarg0r
    Sarg0r
    Aug 28, 2008
    2,807
    +297
    I'd leave it counting, import to Lightroom then export with desired numbering that's what I do. In the grand scheme of things camera numbering is irrelevant in my opinion of course
  3. kBm
    kBm
    Mar 26, 2008
    8,462
    North West
    +2,256
    What os are you using?
    Windows 7 can recognise same file names in a folder then keeps both files with a (1), (2) etc for each file. You can then organise by date to get the correct order.
    You can also do a mass rename too with a no. at the end; yourfilename(1), yourfilename(2) etc. (Just google how to do it).
    I dont think it really matters if you reset the numbers or not.
  4. Faldrax
    Faldrax
    Jun 5, 2009
    1,121
    113
    Chandlers Ford
    +526
    As Sarg0r said, if you use Lightroom for post processing then you can control the Windows file names when you import.
    I personally have mine set op to prefix the camera & year to the file number on import, so I end up with files 'A900-2013-01234.arw' - keeps the files unique across cameras, and also across cameras image number roll-over.
  5. shotokan101
    shotokan101
    Jun 16, 2009
    75,373
    19
    Glasgow
    +25,456
    +1 for Sarg0r's suggestion :)
  6. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
    +1, leave it counting
  7. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    41,408
    11
    13
    167
    ::1/128
    +14,900
    +1 the in camera name is irrelevant for me...
  8. Dexy
    Dexy
    Jul 20, 2010
    1,366
    Aberdeen
    +374
    Keep counting, then when you reach 10k or 9999 on a canon it goes back to 0 but in a different folder name. Try and set it so that the date is in it, that way it will be continuous.
