Photo- cabling advice for new tv above fireplace.
Discussion in 'Home Cinema Building DIY' started by pr1970, Jun 20, 2018.
  1. pr1970
    pr1970
    Jul 12, 2005
    229
    Maidenhead
    +12
    Hi All
    Just having our lounge refitted, having a new fireplace and tv above it (its a low heat fire). Wanted to ask about cable runs. I still have hdmi to go in , think its worth getting some flexible conduit to go from behind the tv to the bottom right corner of the room in case I need to get cables out/in in the future?
    There is a void and we`re having inset shelving put into the walls.
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,331
    The Borders
    +3,424
    '(its a low heat fire)' - preferably it's a 'low' fire as otherwise you may find the TV too high on your wall and uncomfortable to view, do you have the option to mock up the TV set at the intended height and see how you (and anyone else in the house) find viewing it?
    Audio - any plans for an AVR+ Speaker system or a Soundbar?
    Joe
