phono to phono cable info req +wtd
Discussion in 'Cables & Switches' started by fender62, Jun 12, 2005.
  1. fender62
    fender62
    Jan 11, 2005
    144
    19
    cowbridge
    im looking decent phono to phono cable for cd to amp connection not sure whats good, i use denon gear, amp cd etc. ill buy used if the price is right
  2. loadsofleads
    loadsofleads
    Why do you need to use phono ? A coaxial or optical connection would be preferable unless your using SACD or DVD Audio. Are both components compatible with Denon's own digital connection ? This would be the best option as it is said to produce better quality than i link :eek:
  3. fender62
    fender62
    Jan 11, 2005
    144
    19
    cowbridge
    my hifi amp does not have optical inputs only phono
